PerformanceForums
     PerformanceForums... "Hey McLaren, I told you our front wing didn't flex that much" -Vettel @ Spa
Go Back   PerformanceForums > Technical > Engine Management
Reply
Thread Tools Rate Thread Display Modes
Old 05-11-09, 09:31 PM   #1
pauly24
Fixing Nistune R32 idle switch issue
Just an idea for anyone who has a Z32 or R32 ecu for Nistune in there R33.
The RB25DET doesnt have an idle switch, instead it has a variable voltage TPS.
The Z32 copes without an idle switch by defaulting back to the voltage from the TPS. Some people dont have any problems with this, other people notice a slight hesitation as the ECU swaps tables.
The R32 has no idea what to do without the switch and has poor idle characteristics. There is apparently code over on nistune to fix this, all the idle switch does is connect pins 54 and 57 on the R32 ECU to let it know its in idle.
So I'm thinking one can just go buy a momentary contact switch and mount this to either somewhere on the throttle body so it is pushed when its closed or somewhere on the accelerator pedal.
Im waiting on my R32 ECU and my nistune, but once it arrives ill give this a go and let you know how I go.
pauly24 is offline   Reply With Quote
Old 05-11-09, 10:56 PM   #2
GTSBoy
Non player character
GTSBoy's Avatar
Why not just retrofit an RB20 TPS onto the RB25 throttle body?
__________________
Quote:
Originally Posted by bugle View Post
The non GTS's were gay
GTSBoy is offline   Reply With Quote
Old 06-11-09, 07:10 AM   #3
RB30-POWER
RB30-POWER's Avatar
Send a message via MSN to RB30-POWER
RB25 throttlebody should have both.
Manual cars use the throttle position sensor
Auto cars use both the switch and sensor.
Series 2 RB25 throttlebody has both plugs hardmounted alongside each other.
Series 1 RB25 throttlebody has one of the plugs hanging loose which may have been cut off?
__________________
Quote:
Originally Posted by Guido View Post
There's probably as many threads with HRD being awesome as there is of ALLMTR's projects.
RB30-POWER is offline   Reply With Quote
Old 06-11-09, 07:38 AM   #4
pauly24
Ill have a closer look tonight, just people have been making a fuss over this issue for quite a while now (nistune owner even wrote some firmware changes to the ecu to get around the problem). If it was that simple I thought it would of been known to everyone. Then again I may have over estimated the skyline community....
Old 06-11-09, 09:12 AM   #5
Supashake
Supashake's Avatar
I just dont have any trouble but I dont use R32 ECUs on R33s. always use Z32.
__________________
www.iprawa.com
Supashake is offline   Reply With Quote
Old 06-11-09, 04:46 PM   #6
pauly24
Just had a look... your right, there is a spare plug. Check it with the multi meter. At idle closed circuit, off idle open circuit.
Alot of mis information going around about this car, now just to run some wires and hook this up to the 32 ecu and see how it goes.
Old 06-11-09, 10:18 PM   #7
carcrazy
Loving teh titties..
carcrazy's Avatar
Im curious as to why you change the R33 ecu with an R32 or Z32, is there no niztune support for the R33 comp the car came with?
__________________
Lardo to hero.. The 2010 PF fat club here.
Quote:
Originally Posted by Einstein
The definition of insanity is repeating the same action and expecting a different result
carcrazy is offline   Reply With Quote
Old 07-11-09, 08:13 AM   #8
GTSBoy
GTSBoy's Avatar
Quote:
No, the R33 ECU is an orphan - not modifyable.
__________________
Old 07-11-09, 08:42 AM   #9
10sec_rx7
sack riding
10sec_rx7's Avatar
Send a message via ICQ to 10sec_rx7
not yet anyway...
__________________
im a dodgy cunt.... dont believe a word i say....
10sec_rx7 is offline   Reply With Quote
Old 07-11-09, 12:11 PM   #10
GTSBoy
GTSBoy's Avatar
Is that a hint that Matt (or someone else) has something in the works?
__________________
Old 07-11-09, 07:45 PM   #11
10sec_rx7
sack riding
10sec_rx7's Avatar
last time i spoke to him he was thinking of looking at it.. didnt give a time line tho
__________________
Old 11-11-09, 02:26 PM   #12
pauly24
Correct, there is no nistune board for the R33 due to the complexity of the R33 board.
I have done a bit of digging, yes there is an idle switch that is unused on the manual R33's. If you wire this up to the R32 ecu the idle works fine.
Matt also has a firmware fix that uses the TPS voltage to switch the ecu to the idle map.
He has no fix yet for the Z32 ecu (the z32 ecu has something inbuilt that defaults back to the idle map when it realizes there is no idle switch, hence it works fine most of the time)
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Which ECU for nistune for R33? pauly24 Engine Management 5 04-11-09 05:30 PM
Diagnosing alternator/charging issue (R32 GTST) Bill Surewood General 3 22-11-08 10:50 AM
Idle Issue Jayz-1 General 5 12-01-07 03:08 PM
DIY LPG Tuning denmaster General 13 23-04-06 10:18 AM
FS: AutoSalon-Fast Fours-Speed-Hot4s-Zoom-HPI-Street Machine-NZPC mags DoctorEvil Cars - General Car Parts For Sale or Wanted 4 17-10-04 10:23 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
property of swedish industrys, dikhed
