PerformanceForums
     PerformanceForums... "Hey McLaren, I told you our front wing didn't flex that much" -Vettel @ Spa
Go Back   PerformanceForums > Technical > Brake Clinic
Reply
Thread Tools Rate Thread Display Modes
Old 21-10-09, 08:09 PM   #1
uncle
Chairbourn ranger!
uncle's Avatar
Send a message via MSN to uncle
Datto 1600 upgrade
I have a set of VY front rotors and calipers here can I use them on my datto?
Redrill rotors to 114.3 PCD etc.
Anyone done it?
__________________
Downhill crashes so far this year= 10
Quote:
Lonx: in hindsight, that lonx guy is a fuckhead
uncle is offline   Reply With Quote
Old 21-10-09, 08:31 PM   #2
Swill
Syd the Elephant
Swill's Avatar
Caliper will bolt to a late model 180B strut (I think?) though im pretty sure this is right. Disks will need some sort disk to hub adaptor made up.
__________________
Looking for 86 GSXR bits. PM me
Swill is offline   Reply With Quote
Old 21-10-09, 08:41 PM   #3
dattoman1000
Title pending
Send a message via ICQ to dattoman1000 Send a message via AIM to dattoman1000 Send a message via Yahoo to dattoman1000
Shit caliper
Need alot of fluid to work
__________________
Location Perth Western Australia
dattoman1000 is offline   Reply With Quote
Old 22-10-09, 03:19 AM   #4
fly510
Formerly a stupid_cunt
fly510's Avatar
Quote:
yep the caliper/strut bit is on the money. Throw the disks away and buy DBA425 verada rotors and they go onto the dato hub and only require some minor redrilling for locating bolts.
Combine with an r31 rear disk upgrade and new 7/8 master.
Pending good pads (and possibly braided lines), No L series should ever burn up that setup.
fly510 is offline   Reply With Quote
Old 22-10-09, 03:21 AM   #5
fly510
fly510's Avatar
Quote:
Originally Posted by dattoman1000 View Post
Shit caliper
yeh they are not the best but much better then stock and if they are free even better.
Another advantage of this setup is that I recall the 180b struts are shorter meaning the car is instantly lower while retaining full suspension travel.
Thinking about it if the 7/8s is no good (I'd be surprised if it wasnt) a 15/16 will definitely do the job and is bolt on pending you are using a dato booster (180b small can is go as its easy to install).
Old 22-10-09, 09:21 AM   #6
dattoman1000
Title pending
Quote:
Big and free isn't actually better
Think fat chicks here
The upkeep far outweighs the initial investment
You'd probably need a patrol 1" and what 28mm thick disc do you think you'd use ?
__________________
Old 22-10-09, 12:59 PM   #7
fly510
fly510's Avatar
15/16 would easily cover the VT twin sopts & the disc thickness issue is no big deal.
Old 07-11-09, 01:11 AM   #8
Matty T
Anyone have a part number for the 15/16" master cylinder? Or the 1"?
Matty T is offline   Reply With Quote
Old 07-11-09, 05:27 PM   #9
Swill
Syd the Elephant
Swill's Avatar
Matty pretty sure a patrol on is 1 inch
__________________
Old 07-11-09, 06:16 PM   #10
HoonBoy
HoonBoy's Avatar
SWB Patrol is 1inch, got one on the Lancer. All I had to ask for was a SWB Patrol cylinder and they knew what I was after.
__________________
www.hoonboy.com - updated 5th July
HoonBoy is offline   Reply With Quote
Old 08-11-09, 11:27 AM   #11
dattoman1000
Title pending
Theres at least 6 different Patrol masters
What these guys aren't telling you is that you need one for a G60 series Patrol ... late 70's
They come in a few different configurations
Metric threads and Imperial threads (they made this Patrol since 1962)
They also have bleeders on them which can be on the left or right of the cylinder depending which one you get... might get close to the strut tower
Also a Patrol has drums all round so you need to remove the residual line pressure valve in the disc circuit
The most common one to use is a JB1419
And the 15/16" one that I don't think is available anymore is off the 280ZX and its a JB1361
__________________
Old 09-11-09, 11:49 AM   #12
rolin7
Boldy going nowhere
rolin7's Avatar
The 15/16th's ones are still available, you just have to do some searching.
Bleed nipples on the wrong side aren't the end of the world, I installed one like that and just drilled 2 holes in the strut tower.
Guys have even been fitting S14 and/or R32 non abs masters to datsuns these days with success. Redrilling the booster mount holes and using the right length rod.
Another part number I saw was CE130.42605 -> 280zx 15/16th master with nipples away from the strut tower on a RHD.
__________________
Jailbait - Cause the best things in life are illegal.
rolin7 is offline   Reply With Quote
Old 09-11-09, 11:55 AM   #13
HoonBoy
HoonBoy's Avatar
My 1inch has everything in the correct spots
__________________
Old 09-11-09, 12:36 PM   #14
260DET
Q the Stalag State
260DET's Avatar
Yeh they are cast iron though, heavy little buggers.
__________________
Richard........Datsun 280ZXT http://www.youtube.com/FairladyS130#p/a/u/0/rqM9_Wq-TKc
New Lakeside 1:00.77 (R8 Class)
260DET is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
McLaren F1 supercar upgrade package details Billzilla General Discussions 96 16-08-09 06:45 PM
datto 1600 wiring diagram MRMOPARMAN Car Audio & Electrical 4 05-08-09 11:45 AM
datto 1600 bonet/boot lid/ l18-16 nastypaul Cars - General Car Parts For Sale or Wanted 1 25-03-09 10:08 AM
WTD: 1600 Datto ZERO` Cars - Whole Cars For Sale or Wanted 0 18-11-05 12:00 PM
FS: '68 datto 1600 FJ20T - engineered watty Cars - Whole Cars For Sale or Wanted 6 30-08-05 02:35 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
property of swedish industrys, dikhed
