PerformanceForums
     PerformanceForums... "Hey McLaren, I told you our front wing didn't flex that much" -Vettel @ Spa
Go Back   PerformanceForums > Technical > Forced Induction
Reply
Thread Tools Display Modes
Old 28-10-09, 06:44 PM   #31
rolls
If you are really interested give gcg a call and ask them. As far as I know they put garret ball bearings in a standard core and balance the wheels, not the bearings.
As it uses a standard rb25 oil feed and core cover I imagine that is why they need the restrictor, they suggest a 1mm restrictor is used.
rolls is offline   Reply With Quote
Old 28-10-09, 07:00 PM   #32
hemiturbo
aaarrrr... Now it's a bit clearer . Yes they do use garret cores as they can build them to there own specs but still can't see why restrict it unless they remove the factory restrictor maybe. Did they determine which end came out of balance, I assume it was the turbine end. As long a the guys doing it now shaft balance the turbine wheel before the vsr balancing then it would survive. This is the draw back going ball bearing ,It's always expensive to rebuild or change.
hemiturbo is offline   Reply With Quote
Old 28-10-09, 07:03 PM   #33
da9jeff
the curve mate ping power
da9jeff's Avatar
Send a message via MSN to da9jeff
are brand spankers that expensive to go to all this effort?
__________________
'91 Honda integra - 1.28 lala 39.55 'grove For Sale, PM me
'98 200sx - rips a skid
da9jeff is offline   Reply With Quote
Old 28-10-09, 07:03 PM   #34
rolls
Yeah apparently the rear wheel came out of balance due to some weight drooping from excessive heat, this then caused the front wheel to make contact.
Old 28-10-09, 07:11 PM   #35
hemiturbo
OK lets talk excessive heat . It could be too lean, athough you said the mixture a not too lean . Or too restrictive turbine housing ,these are restrictive but only on extreme boost . A rb20 Turbine housing is more restrictive but I doubt it has that. These rb25's have been highflow by many people and not really any excessive turbine heat issues. The only other thing I can think of is a retarted cam timing on the exhaust. Is that possible?
Old 28-10-09, 07:16 PM   #36
rolls
The turbo was only running in the range of 8-12psi so it wasn't anywhere near its maximum flow so that should not have caused issues.
Retarded cam timing on the exhaust, I don't have adjustable gears so if this was the case surely the car would be running like shit? We did take the timing belt off recently to fix an oil pump housing leak however we marked everything and there was no difference in the power levels or the idle etc after reassembling the timing gear.
Is there any other way that this could be confirmed it was not a contributing factor?
Old 28-10-09, 07:23 PM   #37
hemiturbo
I would suggest getting it redyno'd and watch the mixtures while watching exhaust housing temps.... Basicly start back at square one. You could double check your cam timing just to be safe.
Good luck
Old 28-10-09, 07:30 PM   #38
rolls
Quote:
Good luck
Yep that's the plan, I've gone back to a 20det ecu with a nistune instead of a wolf3d v4 so the tune is going to be from scratch and Ill get them to laser gun the exhaust housing/dump to make sure its not cooking itself.
If the cam timing is out surely it would be running like dick though? like that is something I definitely would notice yeah?
Old 05-11-09, 11:16 AM   #39
thechuckster
thechuckster's Avatar
Rolls: the banjo fitting attaching the oil feed to the bearing housing might have a small outlet hole - if so, then that's your restrictor.
__________________
The GT4 daily barge
RA65+3SGE - project procrastination
thechuckster is offline   Reply With Quote
Old 05-11-09, 11:20 AM   #40
rolls
Quote:
That is probably the case, I didn't measure the size of the hole but the guy who built the motor said it had one.
Old 15-11-09, 11:26 PM   #41
rolls
$1000 later and I should get the turbo back this week. Going to get a complete retune with a nistune so I can rule out the tune being the cause of failure, gotta check the exhaust and cat to make sure they aren't blocked either, you'd think you would notice a problem like that though.
Old 17-11-09, 10:03 AM   #42
2JZR31
Now with more ebay parts.
2JZR31's Avatar
Send a message via MSN to 2JZR31
Bummer man. This is why I will only ever buy genuine Garrett turbos (or ebay POS turbos where the price actually matches the quality). I only ever hear these same stories from "custom turbo specialists". Its rare to save money this way.
__________________
10.83 @ 125
Quote:
Originally Posted by sv_i View Post
If the guy was calling you a cunt while running on a conveyer holding a pics of wife or missus while attempting to throw a gearbox on your driveway, would he be able to ask the girl that comes into the servo out on a date while taking a blurry photo of an F40 losing to the GTR filled with coke and hookers with one of them touching their brothers wang?
2JZR31 is offline   Reply With Quote
Old 17-11-09, 11:02 AM   #43
10sec_rx7
sack riding
10sec_rx7's Avatar
Send a message via ICQ to 10sec_rx7
Quote:
what a load of fucking shit...
how is the wheel going to change weight from getting hot? did a blade break off? as thats the only way it is going to change weight.
fuck some people are awesome at spinning shit..
your egt's would be lucky to be 700deg if you tune is good.. ive put 1000deg egt's though garrett turbos and never had a problem..
i did have a garrett turbo die after 3 pulls on the dyno a few weeks back because someone didnt clean out the exhaust housing when it was cast and the casting fell away and mashed the exhaust wheel.. LOL
__________________
im a dodgy cunt.... dont believe a word i say....
10sec_rx7 is offline   Reply With Quote
Old 17-11-09, 11:09 AM   #44
stockymcstock
Full-time wanker
stockymcstock's Avatar
see this wouldn't have happened with a billet turbo. make sure you buy proper reputable brands next time
__________________
Quote:
Originally Posted by Sathanas View Post
I'll need lots of vaseline for you ugly cunts though.
stockymcstock is offline   Reply With Quote
Old 17-11-09, 05:13 PM   #45
rolls
Quote:
Well considering I got the car for $11k with $20k in receipts and a ball bearing turbo with 12 months warranty for $1100 I think I'm still ahead by a long run.
If I was doing the car from scratch myself I would have bought a garret turbo in the first place but as I bought it with it already on the car it was by far the best value option.
Lesson learnt and it hasn't really cost me anything. I could still easily sell the car for more than I paid for it including the cost of the turbo and everything else.
Quote:
It is plausible if you are running 22psi with a blocked cat/exhaust and a lean tune, but I wasn't doing any of that.
Old 17-11-09, 05:31 PM   #46
10sec_rx7
sack riding
10sec_rx7's Avatar
no even then a wheel wont "get lighter" and go out of balance..
you will burn the head off a exhaust valve or melt a piston before the wheel in the turbo "gets lighter"
inconel has a melting point of around 1300c from memory.. you wont get close to melting it..
__________________
Old 17-11-09, 05:36 PM   #47
rolls
you will burn the head off a exhaust valve or melt a piston before the wheel in the turbo "gets lighter"..
I'm sure they would have another excuse if I started arguing with them. It isn't going to get me anywhere so a half price turbo is the best deal I am going to get.
Old 18-11-09, 04:43 PM   #48
rolls
Picked the turbo up today and turns out its an rb20 highflow, not an rb25 highflow like everybody who looked at it told me. This would have caused it to run slightly hotter than it should have, possibly contributing with other factors to its death. Either way it should run fine around 15psi according to the turbo guys here in Adelaide and be very responsive (as already noted).
The balancing nut looks almost like it has been barely touched where as the old one was hacked to shit, this is a good sign as it means they didn't have problems with balancing it like the old one.
Old 18-11-09, 05:13 PM   #49
hemiturbo
Normally those exhaust housings should be ported to slow down air speed on a high flowed rb20 turbo or it will be too restricted.
Old 18-11-09, 05:21 PM   #50
rolls
The housings have definitely been bored out but I'm not sure what you mean by 'ported'. Do you mean that a gap is left between the wheel and the housing?
Old 18-11-09, 05:32 PM   #51
hemiturbo
No ,I mean the intake to the housing from where it bolts to the manifold. I would port this to prevent exsesive back pressure. Similar port methods to head porting. This does make it laggier but the housing size is overly small.
Old 18-11-09, 05:55 PM   #52
rolls
Oh yep that has been done, the turbo guy here commented that the metal was a bit thin as they had hacked so much of it out.
Old 19-11-09, 12:12 AM   #53
floody
31 Number One!
floody's Avatar
Jesus...RB20 turbo is too small on an RB20, let alone on an RB25; would want a hell of a flow improvement. If you just wanted to run 15psi I'd have bunged on a $300 VG30DET OP6 turbo or a Neo one.
__________________
I've seen things you people wouldn't believe, and from this side only! The flight of a half-man, half-bird. Dinosaurs nuzzling their young in pastures where strip-malls should be. Cookies on dowels. All those moments lost in time; gone like eggs off a hooker's stomach. Time to die.
- Phil Ken Sebben
floody is offline   Reply With Quote
Old 19-11-09, 12:20 AM   #54
rolls
Well it isn't an rb20 turbo anymore, it would flow substantially more than a stock rb25 turbo. After speaking to a few turbo manufacturers I believe that the difference is so minimal that after boring the housing/ports out it will be negligible.
It has bigger wheels, ports, housings, garret ball bearings, it will flow much better than a stock 25 turbo. The question is how much worse than a 25 highflow. Yes it does have slightly smaller wheels, but when you combine all these factors I'd imagine it flows a large amount more than a stock rb25 turbo.
From my seat of the pants dyno before it died I would say it was EASILY making 220rwkws. You would never see this with a stock rb25 turbo, and I have been in my fair share, not to mention it made good power to 6 (rev limit at 6k) and felt like it would make a dickload more if the rev limit was increased (wasn't dying off).
Remember 15psi only = 15psi on the same motor and turbo, as soon as you change either of these it doesn't mean anything. Note how 15psi on a 2L motor = ~7psi on a 2.5L motor, the PSI is just a measurement of restriction, it doesn't relate to airflow unless you know the specifications of the motor.
Old 23-11-09, 09:49 PM   #55
PLAYA
BLING BLING
PLAYA's Avatar
Ats?
__________________
Alex
I sell imported timbers. Can supply rough cut or finished. Rose wood, Kwila etc. PM me.
Quote:
Originally Posted by adviliax View Post
My best childhood mate lost his virginity at 13 to a 14yo chick for a packet of ciggies.
My Photobucket
My 1200 coupe SR20DET
My R32 GTR
Chassis dyno 432 rwkw at 30 psi PULP/33%toluene
R32 GTR 290 rwkw @ 16 psi
PLAYA is offline   Reply With Quote
Old 24-11-09, 12:38 AM   #56
rolls
Yeah adelaide turbo services.
Old 26-11-09, 06:53 AM   #57
RB30-POWER
RB30-POWER's Avatar
Send a message via MSN to RB30-POWER
this thing ripping skids again or been too busy?
__________________
Quote:
Originally Posted by Guido View Post
There's probably as many threads with HRD being awesome as there is of ALLMTR's projects.
RB30-POWER is offline   Reply With Quote
Old 26-11-09, 10:57 AM   #58
rolls
Put the turbo back on but I need to get a dump gasket for the exhaust. It isn't registered and need to go through regency to get on the road so I need some more things done before it will be ready.
Eg plumbing up the catch can to the intake, replacing the carbon canister and a few things like that. Also need to go pick up my stock eco + nistune so I can sell the crappy wolf3d thats on there. Once I get the turbo plumbed up I will start it up and idle it down the road so it gets some oil flowing though, been about a month off the road now.
Hopefully shouldn't be long
Old 04-04-10, 10:15 PM   #59
T0nyGTSt
black women taking a dump
T0nyGTSt's Avatar
yeah i had a turbo rebuilt and it fucked too
agree with old mate RB30-POWER, had much better luck with 2nd hand turbos and just running them until they bust and then getting another one
last stock rb25 turbo cost $70 off ebay...
__________________
Quote:
Originally Posted by some moron
"to avoid having your license suspended and in the interests of all road users, you are urged to improve your driving practices and adhere to the provisions of the driving law"
Quote:
Originally Posted by the Wizard
Between the time when the oceans drank Atlantis, and the rise of the sons of Aryas, there was an age undreamed of. And unto this, Conan, destined to wear the jeweled crown of Aquilonia upon a troubled brow. It is I, his chronicler, who alone can tell thee of his saga. Let me tell you of the days of high adventure
T0nyGTSt is offline   Reply With Quote
Old 04-04-10, 10:33 PM   #60
rolls
Since the new turbo has been put on the car blows no smoke at all indicating that the oil seal was leaking.
Quite likely that a lack of oil flow could cause the bearing to overheat or chew itself out and become unbalanced?
I am quite confident that this is the cause of the failure.
Whilst I have been quick to bash GCG in this thread I would have to say the performance of the turbo is fantastic, amazing response and makes a lot of power. Currently only running 10psi until I get the car tuned properly but it is making 197rwkw at a 6000rpm rev limit.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
NISSAN Engine Designations Cameron_Datto General 19 12-01-07 10:38 PM
King Of Europe drag race, June 2005 kwottro General Discussions 37 28-10-05 05:57 PM
where to get a manifold made up? fourwheeldemon General 15 02-05-05 07:09 PM
BRIS//QLD Wanted: R33 Rb25det Stock Turbo onnosgsr Cars - General Car Parts For Sale or Wanted 2 22-02-05 03:55 AM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
property of swedish industrys, dikhed
